Spraying with stock pcv system?
Are there any issues with spraying with a stock pcv system? I know LS1's have a oil consumption issue. Is a breather enough? Catch Can? Putting a 150 shot on a 00 SS over the winter want to get stuff worked out ahead of time. Plus I wanted to post here to hear it from the guys who are spraying already. Thanks
The stock PCV system will be fine. Running a catch can is up to you, I run one and it usually needs to be emptied once a season. I think that they are worth it. If your poping the dip stick you more than likley have a bigger problem.
