New to Nitrous need some help ZEX
Okay
Looking at buying a DRY ZEX KIT
For my 96 lt1 Formula ws6
the most important thing for my car is safty
I want the nitrous power but only what the car can take
WHAT SIZE SHOT CAN I USE?
I would like to use 75-100
I have 88,000 miles on it. Motor runs great
rebulit trans at 70,000 something I forget
a few bolt ons
3.73 rearend
OFF ROAD Y-PIPE
FLOWMASTER
HPP III
52mm throttle body
1900 Stall
Pacesetter Headers soon
What can my car take without damaging it.
currently it is daily driven.
Thanks guys
Edlt1
a few bolt ons
3.73 rearend
OFF ROAD Y-PIPE
FLOWMASTER
HPP III
52mm throttle body
1900 Stall
Thanks guys
Edlt1
Zex makes a good LT1 dry kit. The car itself will take a 150 shot however the fuel injectors will not. If your injectors are stock as old as they are they probley need upgraded anyway. The best thing to do is to log the duty cycle. I suggest upgrading the fuel pump and injectors. Or go to a wet system. We carry anything you may need and can help you tech wise. Let me know if you have any questions.
Thanks
Dave
Thanks
Dave
You have to remove the Hypertech Power Programmer 3 first before you spray or you will lean out and cook your pistons.
I would suggest to remove it and have PCM4Less program you stock ECU with higher rate injectors along with a 150 shot.
What should I up my injectors to?
I was looking at getting
the walbro 255lph fuel pump.
with the pump and injectors
will everything run fine durring normal driving?
Thanks
Ed
Thanks
Ed
Get a Walbro 340, not exaclty sure what size injectors you should step to. I think you need to program the computer to recognize the new injectors, and yes it will run just fine afterwards.
