Dry 100shot and forgetting to take traction control off
What would happen, say if you were driving and you hit the gas but forgot to take the traction control off. This is a NX dry 100shot, with window switch. I was just wondering would it just go lean, or would the window switch sense that the rpms are getting lower and cut off at say 3200 were it was to be activated. Just curious, or would it just go very lean and blow ????
I have done that in the past in my case a few small pops nothing bad,sounds like when you hit the juice and you dont purge it first. did not damage anything as far as i can tell later SSONE
Originally Posted by toecutter_tx
Doesnt the traction control cut fuel (like the rev limiter) when it engages?
If so wouldnt the lean condition hurt the motor?
Originally Posted by Robert56
Nope, no fuel tampering with traction controll.
Robert
Robert
The traction control reacts differently for the drive by wire and the cable. The GTO breaks traction and the pedal pushes back at me. If I was to try to run the 1/4 mile with it on, I would turn high 14's.
