NX Kit Wiring Check!!
Old 12-05-2005, 11:19 PM
Nakoz's Avatar
Default NX Kit Wiring Check!!
Ok guys this is my first nitrous setup !!! I have made a wiring diagram with the equipment I have. It was a little confusing to me at first but I think I finally got it. Attached is the diag I made, and i was just wondering if someone could look it over real quick and let me know if I am missing any thing. I am mostly concerned with the MSD switch. I think I got it right, but it doesnt hurt to ask.
Thanx in advance...
Nakoz
File Type: pdf
Old 12-05-2005, 11:32 PM
Closed ex-Sponsor Account
NXRICKY's Avatar
looks good
Old 12-06-2005, 09:19 PM
Nakoz's Avatar
Thanx for the feed back NXRicky...
Old 12-06-2005, 09:35 PM
GrezMunky's Avatar
Looks good you *** lol!!!! now have the marbles to actually use it.
Old 12-06-2005, 10:20 PM
BadAssFast's Avatar
Originally Posted by NXRICKY
looks good
I hate to come in after Ricky has given a good...but I'd run your RED from MSD to arm only to contimue through arm switch to WOT. I'd get a Switched Ignition or Bat +12V for the opener and heater from a source other than the one from the MSD red wire. Make sense? I'll PM Ricky to be sure i'm not on crack. Need fuse at Battery, I'm doing a fuse on my +12v feed line to heater and opener.
Old 12-07-2005, 08:43 AM
NXRICKY's Avatar
Looking at the Drawing again the switch panel should be keyed 12 volts, not a constant.. Always used a keyed source on control wires.
Thanks Macon for bringing that to my attention.
It would work but keyed is better.
Ricky
Old 12-07-2005, 12:13 PM
Nakoz's Avatar
Yea i was planning on using a keyed source, just forgot to include it in the drawing. Thanx for all the info guys, and to GrezMonkey.... Go LUBE up so I can spank you!!!!
Old 12-07-2005, 01:05 PM
Robert56's Avatar
My self I always run purge noid and bottle opener through relays for safety. I don't want the amp load going thru my switches (and you don't want your keyed 12v source powering extras to much combined load?). NX dosen't do it this way? I also run a fuse to each supplied amp load 12v going to realays? The tach/shift light is the tach input from PCM, right, light can tap in there, but just clarify for those reading along.
Robert
Old 12-07-2005, 01:39 PM
NXRICKY's Avatar
Robert no need for a relay with a remote bottle opener, with the NX style too much of a head ache to hook up relays and since the thing does not draw but a few amps.. And the purge now only pulls 3-8 amps depending on mfg, and the switch panel Nskoz is using has good amp carring switches...
If using a large noid like Nitrous Outlets, big show or Dynotunes big purge then yes you need a relay.
And final all high amp load should have a proper breaker on it, low amp stuff pull from a keyed 12volt with a 10amp fuse is more than enough. When whas the last time you opened your bottle and had the purge pushed at the same time...
Ricky
Old 12-07-2005, 02:14 PM
Robert56's Avatar
Ricky
Thanks for the insight on the NX wiring. yea, I am probably a little over kill on the wiring safety, but I like it that way. Opening bottle and purging at same time, not going to happen.
Robert
Old 12-07-2005, 07:29 PM
BadAssFast's Avatar
Who could be more "safe" than Ricky or Robert? I agree a fuse on every load and a chicken in every pot.
Old 12-08-2005, 09:38 PM
Nakoz's Avatar
Man you guys know your wiring... I never really considered how many amps I would be pulling with the this setup... but its good to know that it looks like I am on the right track. I will be putting fuses for each 12volt hook up I do, just wasnt sure if it was worth the effort at first... Thanx Ricky and Macon for all your info.... me's appreciate it.
Nakoz
Old 12-08-2005, 09:52 PM
NXRICKY's Avatar
Your welcome, I like doing wiring stuff, use to add extra $$$ to the kitty in the past. Cheer E O
Ricky
Quick Reply: NX Kit Wiring Check!!
