Fuel pump upgrade
Fuel pump upgrade
ws6
Planning on doing a 100 shot of Zex or NX
looking at getting a
walbro 255 iph
do I get high or low pressure?
and what size injectors would best for a mostly stock car with a few mods
Exhaust
headers,off road y-pipe and hooker cat back
walbro 255 iph
Exhaust
Your stock injectors will be fine as long as you're not doing a large dry shot. I believe Walbro pumps only come set up for EFI, so it will be "high pressure" unless the regulator you use can be set for low. I'm going to assume this pump is for the factory fuel tank. If it is you might want to do a bit of research and look at the Racetronix kits. They won't require you to cut up the factory fuel system like a Walbro pump will.
Matt
Matt
Originally Posted by edlt1
ws6
walbro 255 iph
Exhaust
walbro 255 iph
Exhaust
