Dynotune 2 Stage Window Switch
Does any body have a wiring diagram that shows how to wire this switch? I have the switch all wired up except for the two outputs. Do the outputs go directly to the soleniods? Do I still need to wire in relays or does the switch act as the relays for both stages. This is the first time I have wired up a system using this kind of switch and I just want to make sure its right. Thanks!
