NX 90mm TB or Direct Port?
Which one would you guys recommend? I currently have two new NX Pro Power solenoids, and I am considering what type of setup to use. I will be changing my intake to the 90mm FAST and possibly getting a NW 90mm TB, so I thought that I might as well get the direct port with the braided lines from Nitro Dave.
But I figure that would cost me an extra 1300-1400. If I get the 90mm Fast and the NX 90mm TB, I can save all that money.Will the NX TB work almost as well as the a direct port? Would it be worth it for a 150-200 shot?
Thanks
Thanks
We can help you with the Fast Intake and the NX 90mm throttle body..The only confusion im getting is are you asaying will the throttle body with a nitrous discharge work as well as a directport? If so the snswer is no.A directport is the most precise way of making sure the currect mixture gets to each intake runner. However on smaller shots a directport is not near as needed as on larger shots.
How much are you spraying?
Dave
Dave
If at a 150 shot or less, the TB setup will be fine.
Any larger and DP will be the better choice as well as looking WAY cooler. Big CDI factor with a direct port system...
Good luck either way!
