NX Shark Nozzle ?
Old 12-12-2005, 11:21 AM
oange ss's Avatar
Default NX Shark Nozzle ?
does the spray exit at 90 degrees to the nozzle or a slight angle ?
Old 12-12-2005, 11:26 AM
383LQ4SS's Avatar
Im pretty sure its a 90
Old 12-12-2005, 11:34 AM
NXJeremy's Avatar
383's right. Are you looking for a nozzle with a different exit design? We also have nozzles that spray straight out the end of the tip.
Old 12-12-2005, 11:46 AM
oange ss's Avatar
no, i mounted mine in the rear MAF end, i was tryin to keep the spray from sprayin down one side of the inlet tract, so i thoight i'd mount it at a slight angle so the stream would intersect in the middle...does that sound right ? I guess i could take a pic if you really wanna see, on second thought is that too far away from the t body ?
Old 12-12-2005, 12:36 PM
383LQ4SS's Avatar
No that will work fine. I have mounted a bunch there. Just be sure its close to a 90 degree angle to air flow. The extra distance you have will help distribute the n20/fuel mix even if its not exactly 90 degrees. You should be fine.
Old 12-12-2005, 02:38 PM
oange ss's Avatar
cool thanx......i think that 415 could use a little more cam
Old 12-12-2005, 04:53 PM
BigSteele's Avatar
yeah i was just wondering about this too. I thought since the mixture would have some momentum traveling straight it may spray out just a little past 90* but i put it so it is just barely angled to the center of the TB
