NX TPS Switch Which wire..
Old 12-24-2005, 04:00 PM
SSLS1's Avatar
Default NX TPS Switch Which wire..
On the NX TPS Switch Which wire, which wire is the TPS output wire????
Old 12-24-2005, 04:22 PM
kazfan30's Avatar
On the Trick Switch its blue....so it can tap into the blue wire on the TPS, so is there any blue wires on the NX box...maybe that helps
Old 12-24-2005, 08:13 PM
BadAssFast's Avatar
Are you asking where the PINK on the TPAS goes to ? Or what wire is the output voltage on throttle position switch in the throttle body? On my 2000 Z/28 there are three wires...Black, Light Green and a Dark Blue. The Dark Blue is my WOT voltage. The other way I can describe mine is to look at the plug and orient the plug as a triangle...it is the top connection. Maybe this will help:
This may be wrong or I may have misunderstood the question...check for 4-5 volts DC with a volt ohm meter with motor off, ignition on at wide open throttle.
Old 12-25-2005, 05:14 PM
SSLS1's Avatar
thanks thats what i needed
