BIGGGG shot guys (400+)
What are you guys doing to keep your bottom ends alive? I am planning on running a single or dual stage progressive direct port on a forged bottom end and will be spraying around 350-450hp combined hit. (secondary fuel system of course ).
Im going progressive hit, so do i still have to worry as much about torque spike as a big dual stage? Will my stock ls1 block distort like crazy? Hell if I could get away with running the stock block and crank then I'd be doing the motor work this week (although i've never seen anyone successfully making 900rwhp or so on the stock crank on a n2o motor).
Or is it worth the money in terms of strength to just go bad dude and get an iron block with a fully forged crank (and in that case will the eagle hold the abuse)?
I figure this will probably be the easiest way to get me to my goals
Thanks for your inputs.
Nate
Nate
8 SEC SLOPPY SHOT!!!
I would get the block drilled for 1/2 head studs and get some aftermarket heads.If that is the size shot you want to run id go iron block.Big bore short stroke (stock) and spin the **** out of it.Cometic made some new o ring style head gaskets i just seen then this year at sema.Down side is there not reusable.Might wanna give them a call direct to get the low down.Good luck
Powell has a 408 with Wiseco pistons that we've put 400HP through 15+ times. No problems with the headgaskets or anything. He's got SCE Titan headgaskets, LS6 heads, and standard ARP head studs.
What rods and crank? Heads? Compression? Cam? Times please? Can you give me some more details please? Thanks man.
Nate
Originally Posted by Robert56
Nate, that's not fair, how am I going to keep up with you?
Robert
Robert
Nate
Originally Posted by Nate_Taufer
Sounds like im going 408 then. Did he have gas ported pistons? Im not sure of the benefits of a gas ported piston on a mainly street car that will see 150-200 shot most of the time and 400 when it's actually hooking.
Nate
Nate
Here's a link from Cold Fusion, as we are redoing our direct port page (has the EFI kits only at this time). These kits are good for upto 600+ hp and a bargain at $595, with high quality. We have plenty of pro guys running these kits. I am also trying to get a DP as one of my stages, but will be no where near the 400hp shot. Gutted the interior of my car today for my roll gage, and other upgrades coming. The 408 deals are great, and that is the way to go, imo, if going biggggg.
Nitrous Direct DP kits
Robert
Robert
Nitrous Direct Direct Port kits
Robert
Robert
Nate
