Spraying my blower setup?
I know I am already at and beyond the limits of the stock bottom end with my current setup. Procgarger D1SC, mild blower cam, LTs, Corsa Exh, Spec stg 3 clutch, and an external fuel setup.
Basically I am on the verge of ordering a 408 for my setup along with some new heads and a larger cam! All setup for the Blower/Nitrous setup I want to run.
So what do you guys suggest? Should I run a single stage plate setup? Should I run a nozzle setup in the intake tube? Should I run dual stages or just get a progressive controller for the single stage?
I am almost certain I will end up with an NX kit, unless I get a nitrous outlet kit, because I would like to have that black bottle...LOL and they use NX noids anyways! Any other recomendations for what I want?
For now with the stock bottom end I am just going to spray a 35shot until I get my 408 then I will step up to a 75shot or maybe larger just depends on where I am at after the swap.
Any help you can provide is appreciated!
Thanks
Mick
Thanks
Mick
