Unsure about wire on MSD Window switch
I dont know if the yellow 18ga wire that supplies the ground to my solinoids should be wired directly to the solinoids or if it should be wired to a relay. It just seems funny that you would supply the ground with the little wire from the MSD unit. I'd be affraid of burning it up. How did you guys run yours?
Originally Posted by oange ss
or straight to a relay if you're not usin a FPSS
Originally Posted by 227Hawk
Yellow should run through your Fuel Pressure Safety Switch (FPSS) then to ground.
Hawk
Hawk
So I run the yellow wire to the FPSS and then from the FPSS to a relay?
Originally Posted by NXRICKY
Ricky
Originally Posted by NXJeremy
That's right. Run the yellow wire from the switch to the FPSS, and run the ground wire from the relay to the other side of the FPSS.
Closed ex-Sponsor Account
No bother at all, this is what this forum is for sharing information to help everyone have a safe and happy nitrous time. Let us know if it all works out for you..
Ricky
Ricky
do you a WOT switch or not ?
