MSD Digital Switch, Recommended?
Greetings all.
I am working with a Corvette Director here on LS1Tech on buying a used TNT F1 Kit, and he has a MSD standard switch that goes with it. Is this any good? Should I fork up extra for the digital? What am I really gaining? I would like to wire up a 1st gear lockout switch too, and am not sure if I can do that on the standard.
Thanks.
Thanks.
I love my digital window switch. No worry about pills and it makes testing easier because you can set the ON RMP at 0 or what ever you want while still idle and on the dyno. I just wish they made a box that could retard my timing at the same time.
The MSD works good. But Our Trick windowswitch is my favorite. This unit has a anygear lock out, Built in TPS, and dual window switch. This unit is also digital.
http://www.nitrousoutlet.com/outlet/...section_id=137
Dave
Dave
Dave
Dave
Damn that is trick...!
Whats the benefit of the dual window switch? Two settings for different applications?? :newb:
