NX Switch Panel/TPS Wiring
1 Post
With the NX switch panel 15896, does the GREEN TPS relay wire connect to Pin 1 "Blue" on the switch panel? Is it providing a 12 volt switched signal to the TPS relay allowing the TPS to turn ON?
Closed ex-Sponsor Account
http://www.nitrousexpress.com/Instru...witchpanel.pdf
This is not exactly what you were looking for, but the switch panel it only controlls low amps.
Ricky
1 Post
Ricky
Follow up...
1- The W/S then switches a relay that gives ground to the solenoids
2- The FPSS can be deleted and pin 85 goes straight to ground?
Actually that's great...my mind is jello right now.
Follow up...
Follow up...
The FPSS and or WS controlls the ground side of the relay.
Ricky
1 Post
No your W/S yellow (for MSD) will go to the85pin and the black will go to ground.
Ricky
Ricky
In essence just swap out the FPSS for WS?
