? about spraying with my cam
Hey guys I need to know from the guys running cams & nitrous if this is a cam that will work good with the future nitrous set-up I plan on.
Cam Specs: Custom Grind Comp 232/238 .595"/.585" 112LSA
Future nitrous plan: DRY 100 shot
Any help is appreciated
You’ll be perfectly fine spraying that cam. My only two suggestions are with the fuel system, since you’ll be spraying a cam car watch your FP (you might need a new pump) and keep an eye on the injector pulse width.
Matt
Matt
