Spare tire well mount???
Old 01-22-2006, 08:00 PM
2002LS1Z28's Avatar
Default Spare tire well mount???
is there any way to make a mounting plate to mount the bottle in the spare tire well??? pics??? or is it just worth the 45$ investment to buy one pre made??
Old 01-22-2006, 09:07 PM
ws6formula98's Avatar
I Made My From Two 7 In. Spacers And Bolts, You Just Put The Spacers Between The Mounting Plate And The Car. Its Only Like $5 At Ace.sorry No Pics.
Old 01-22-2006, 10:01 PM
The Sad's Avatar
I bought some strips of metal from Home Depot and connected them from where my jack went to the lip where the antenna is. Then put the bottle brackets onto those. I don't have a pic of mine, but I think I have some similar pics from others. Let me see.....
Found it - mind kinda looks like this
Old 01-22-2006, 10:09 PM
v8juice's Avatar
I used the brackets/mounts that came with the kit,with a little adapting it fits in the wheel well quite nicely
Old 01-23-2006, 12:48 AM
Mike Comp T/A #57's Avatar
I used the stock brackets. I mounted them on the side.
Old 01-23-2006, 02:05 AM
TwoFast4Lv's Avatar
I custom build the 15Lbs mounts. Go to 860 for anice bolt in for 10Lbs mounts
Old 01-23-2006, 07:32 AM
860 Performance's Avatar
The bracket Dave sells works with 10 and 15lb bottles. He has some pics of 15lb bottles installed, and there are some pics posted somewhere. I'll see if I can find them.
Vinny
Old 01-23-2006, 08:12 AM
BadAssFast's Avatar
860 Performance with a 10 lb bottle. I got mine through Nitrous Outlet.
Old 01-23-2006, 10:55 AM
TwoFast4Lv's Avatar
Vinny
I have installed them with both 10 and 15 Lbs bottles. They are prefect for 10 Lbs bottles but the 15s are a very tight squeeze We tried NX ,CF and NOS bottle brackets and the valve always wanted to hit the wheel well
VERY nice product. that is why I mentioned it
Old 03-16-2006, 04:48 PM
Jimmy P's Avatar
What brackets should one use with the 860 mounting plate?
Old 03-16-2006, 04:57 PM
Nitro Dave's Nitrous Outlet's Avatar
On the 15lb bottles you will need to space up the front bracket so that the valve clears the fender well.
Dave
Old 03-16-2006, 08:52 PM
Mach1killerls1's Avatar
i just used a street sign that i found cut it in half and bought some L brackets from a local hardware store and then just drilled the holes and mounted it. best thing about the street sign is that its forged aluminum and weighs damn near nothing.
Old 03-17-2006, 10:42 AM
1BADAIR's Avatar
I used 1 inch square aluminum tubing about 1 1/2 long to raise the front of the 15 pound bottle to get the opener to fit with the 860 bracket
Old 03-17-2006, 11:44 AM
daryl2cb@yahoo.com's Avatar
made my own with steel, but then again you can buy one too, personally I like to spend money on things that can not be made easily. Pics in my sig under nitrous
Quick Reply: Spare tire well mount???
