MSD Digital Window users
I believe mine is hooked up wrong. This whole kit came froma friends car whos doing the work on mine, he's wired it the same way as on his. First off, when the car is off, or even just at idle, I can arm the system and trigger the WOT switch and the solenoids click. I don't think this is right, the ranges set are 2800-5800. My question is, where did everyone who has this hook up the Yellow and Grey wires? I want this to work right so I don't kill the car.
Thanks
Thanks
1 Post
Thanks
Thanks
The yellow and gray shouild not be wired at the same time. Eventhough the link is to a pilled RPM switch wiring is the same.
Sounds okay, as long as the FP safety switch (grounded) goes to the other 2 wires on the solenoids, while the other 2 wires on the solenoid go to a relay source (usually a blue wire).
try this if your using a relay which i recommend- I thought i blew mine out- Where is yours mounted mine is mounted right in the center console- To wire it into a circuit try this http://img42.imageshack.us/my.php?im...0wiring0uf.jpg
