Can a relay go bad?
Old 01-30-2006, 03:45 PM
02Vortech's Avatar
Default Can a relay go bad?
Can a relay go bad on a nitrous system? b/c on the bottle heater 3 pegs are getting voltage but on the nitrous relay only the one comming directly from the battery is getting voltage- the switch was turned on- the arm switch was getting voltage-
Old 01-30-2006, 03:46 PM
Restricted User
NOSjohn's Avatar
yes it can
Old 01-30-2006, 03:56 PM
02Vortech's Avatar
i tested the voltage going to the arm switch, from arm switch to WOT switch, and voltage from battery to relay..... Would there only be voltage going to the relay on the WOT switch side if the Switch is activated?
does it sound like mine is blown?
Old 01-30-2006, 04:53 PM
Moderator
jimmyblue's Avatar
Go at it methodically, get out your wiring diagram (or draw
one that represents reality) and measure voltages at each
point in the chain looking for which elements have a drop
across them. Remembering that ground is a voltage too,
and relays need both source and sink for the coil to work.
Old 01-30-2006, 06:20 PM
02Vortech's Avatar
okay so i went through everything as far as voltage checks out but i cant figure out how to check the voltage to the noids- it has to be run through the window switch and grounded- but i went to do a couple test runs and i didnt have any nitrous left...... so tommorow i will update-
Quick Reply: Can a relay go bad?
