Solenoid "ON" status LED
1 Post
So what kind of solenoid on/off status indcator would you suggest? I though about hanging a LED off the solenoid relay letting me know when the relay is passing current to the solenoids?
Moderator
I've actually bought a whole mess of LEDs & resistors
with the plan to put arm/opener, enable, and solenoids
status lights into my dash bezel. Simple enough. You
probably want to add a good snubber diode to the coils
though, because I don't think LEDs like reverse breakdown
much. A cheapo 12V bulb would be a tad simpler, cheaper,
tougher; find them in colored lens assemblies at any
AutoZone type store.
Here's what I have. The two green lights are my 1st and 2nd stage rpm activated noid lights. You can either use them with noids plugged in, or without noids plugged in for checking ws activation per rpm. I don't have the 3rd stage light in yet. The orange light is my second stg power light.
Robert
Robert
1 Post
Robert
Robert
1 Post
Moderator
Right, a back-diode across the coil to snub any swing
below ground. Also you would want a series resistor in
the LED - Pin30 leg to limit current, value based on
running about half the rated LED forward current.
1 Post
Originally Posted by 860 Performance
Robert, I like that panel.
I really like having the idiot light for solenoid power escpesially when running a FPSS. I can save lots of time when de-bugging.
Robert
