Direct port ?'s
Old 05-05-2006, 03:41 PM
Cbrakllr's Avatar
Default Direct port ?'s
Do you think that I would be safe running a cold fusion direct port kit with a 200 shot on my D.D. ? I would run a dedicated fuel system and a progressive controller and all the necessayr supplies. I would only spray once a month on the track only for about two runs. So the car wouldn't be sprayed all the time like most of you think it would be. It would only be for a few months till I forged but I think I would be ok doing this but I just wanted to get all your input. Thanks for the help in advance. Gregg.
Old 05-05-2006, 07:45 PM
Robert56's Avatar
Yes you could. however, the tune will need to be right on. Only you can make the choice of this size hit on your dd, as you may be pushing it. If it's your only ride, maybe a smaller hit would be in order?
Robert
Old 05-05-2006, 08:02 PM
krazy4's Avatar
just like ^he said
it is pretty risky but people are pulling it off.
just be safe and run a 150 shot
Old 05-05-2006, 08:39 PM
Restricted User
CAT3's Avatar
Why push the limits if your worried? If you cant pay, dont play! I had the same deisres before, and I successfully shot 220, 175 and all that. Do I think its safe, no I dont. If the tune has a error, the octane isnt right, or gee the catastrophy if a solenoid gets dirty, stuck etc is only going to be worse. So many things to have happen that as Robert said, you are your best source for advice. I say if you cant afford to have it pop #7 cylinder ring lands, dont spray it with 200. But, if you do, and you use all the safety hardware, including plugs, race gas, tuning, fpss, ws, pro-controller, heater, etc etc.. then I think you'd be just as quick as running a less conservative 150 shot. But thats me. GL
Charlie
Old 05-06-2006, 01:20 AM
Cbrakllr's Avatar
Thanks for the help everyone, I guess I will just run a 150 shot for now. Thanks for the help.
Old 05-08-2006, 11:58 AM
Nitro Dave's Nitrous Outlet's Avatar
I agree. On your daily driver the 150 shot would be the way to go. Also get it tuned..
Dave
Old 05-08-2006, 08:25 PM
brad8266's Avatar
Originally Posted by rmitchell242
what kind of tune do you go for if on a direct port if you are spraying fuel and nitrous? are you mainly retarding timing?
Well, you can tune it NA to 12.5 -13.0 AFR and then adjust fuel jets to get your AFR on the spray where you want it. And you can then just pull a little timing as well.
Old 05-08-2006, 08:57 PM
brad8266's Avatar
In this type of set up you would almost need 2 tunes one for motor and one for spray? the map sensor would not pick up the spray would it?
assuming you wanted max power out of the motor sometimes
No you can have one tune. You can tune it NA and then try different fuel jets to get the desired AFR. Only dry kits rely on sensors to adjust fueling. Wet and direct port kits control fueling by the fuel jets that you put in.
I tuned my wet kit for NA and then just sprayed on top of it with the right fuel jet to get me the desired AFR.
Old 05-08-2006, 09:40 PM
brad8266's Avatar
Oh I see. You would need to pull a little timing on a 200 shot in order to keep it safe. They have a device out that will adjust the timimg for when you are spraying. I dont remember who makes it though. I am sure a sponsor will see this and let you know.
Old 05-08-2006, 10:27 PM
Somebody09's Avatar
RamCharger Timing Tuner I think is what it's called.
Old 05-09-2006, 01:44 AM
Restricted User
CAT3's Avatar
Another way to tune the timing, is this...
Reduce the advance a couple *'s up til .76 g/sec, which is were most NA applications will max out airflow wise (if yours is higher like .80 then go to that amount). Now, after that go ahead and reduce timing from .80+ g/sec through the remaining table. I have done this and it works very well. Reason is, while on the juice, your at WOT. At WOT your pulling that "x" amount of air naturally, so when you hit the spray that amount is normally surpassed so very quickly. I think in my logging, looking back at histograms and table, it see's less than .76 for a not even 3 frames, so less than a second.
Anyway, thats how I've handled the timing aspect. Then on wet, as Brad mentioned jet changes, fuel jets seem to change a larger amount than nitrous jets, but also the remember the bottle pressure will effect the AFR. If you adjust your jets for say 12:1 afr @ 800psi and then you hook a heater up and have it at 1100psi like I run, you'll lean out to something like 13:1. Yes there is a calculator around somewhere that shows the difference in psi vs AFR but too tired. GL
Charlie
Old 05-09-2006, 07:41 AM
Matt@HSW's Avatar
You will want to if it was advanced any. For that you could run a LS1 Timing Tuner to pull timing only when you spray or you could run a higher grade fuel when the nitrous is activated to compensate for the additional timing.
Matt
i understand that idea that you do not need to tune for fuel but i was under the impression that you want to run less timing when spraying and my car loves timing on motor. Right now on my dry shot i think i am retarding 7*
is it cool to run 28* on a direct port? 200 shot
