nitro dave/860 f-body bottle mount....
Old 05-09-2006, 09:34 PM
sprung_monkey's Avatar
Default nitro dave/860 f-body bottle mount....
does anyone have pics of this installed??? sorry just tired of no mount or brackets for that matter..............went ghetto with the wrapped up in jacket idea....i know stupid but im fixing it now i hope
Old 05-10-2006, 09:49 AM
Chris@NitroDaves
Guest
Posts: n/a
Hope this helps.
10lb Bottle
15lb Bottle
-Chris
Old 05-10-2006, 03:40 PM
oh **** i can fit a 15lber in there.........fa sho! thanks chris once i get my cash together you guys will be taking it all
Old 05-10-2006, 03:47 PM
daryl2cb@yahoo.com's Avatar
wow, I did not know a 15 would fit on that, sweet, question I have is how does that thing mount on the quarter panel side? I made my own plate, and I had to run x bracing under it, I caught on bolt on the attenna support, same mounting place for that plate? Just curious
Old 05-10-2006, 03:48 PM
Big Geek's Avatar
Awwww sookie!!! That looks clean and sneaky. Looks like ole Dave is gonna be getting some more of my money. I also wish he would make a plate for the Hemi's. Hint, hint, wink, nudge!!!
Jim C.
PS-How much are they?
Old 05-10-2006, 04:04 PM
Chris@NitroDaves
Guest
Posts: n/a
860 Bracket
-Chris
Old 05-15-2006, 08:02 AM
Big Geek's Avatar
Originally Posted by Chris@NitroDaves
Thank you sir.
Jim C.
Old 05-15-2006, 09:06 AM
Nitro Dave's Nitrous Outlet's Avatar
Jim C.
Send me a picture and a throttle body. Ill see what I can do.
Dave
Old 05-15-2006, 04:03 PM
Big Geek's Avatar
Dave
I will start looking for one on ebay!!! Thanks Dave.
Jim C.
Old 05-15-2006, 07:08 PM
OK sounds good.Take a picture of the engine bay and hit me up before buying anything.
Dave
Old 07-20-2006, 09:12 PM
just bringing this back up..........will i have to cut into the plastic cover to run this?? if i can at all
Old 07-20-2006, 09:29 PM
No.. You will have to take it off and then put it back on when the bottle is mounted.
Dave
Old 08-28-2006, 02:32 PM
BADSZ28's Avatar
Is drilling required for this?
Old 08-28-2006, 03:05 PM
Chris@NitroDaves
Guest
Posts: n/a
Yes you have to drill two holes in the body of the car.
-Chris
Old 08-29-2006, 12:35 AM
TwoFast4Lv's Avatar
Old 09-08-2006, 12:13 AM
JLMoses's Avatar
Dave....just outta curiosity, with the 15lbs bottle mount....I have the kit and everything just makin sure i got it all before i go to installing. Can i keep the 3 1/2 inch speaker in the rear panel and run this mount plate with a 15 lb bottle and electric opener? or will the speaker have to go? just a thought. thanks Justin
Old 09-08-2006, 09:15 AM
Billiumss's Avatar
Exclamation
Hope this helps.
15lb Bottle
-Chris
How much for those brackets and what model number are they? I have a NOS 15lb bottle. Do you have any pics of the bracket installed without a bottle in place? Can you post install instructions?
Bill
Old 09-08-2006, 02:46 PM
1BADAIR's Avatar
that is my car with the 15 in it. I had to remove the mid and tweeter to get the opener to fit. I also used 1/2 square aluminum tubing to raise the front bottle bracket up about 1 1/2-3/4
Old 09-10-2006, 08:50 AM
Billiumss's Avatar
Would you mind taking a few pics of it with the bottle out and posting them? Does it mount to the antenna mount?
Bill
Old 09-10-2006, 09:37 AM
1BADAIR's Avatar
1 bolt goes to the antenna and two go down through the frame rail
Quick Reply: nitro dave/860 f-body bottle mount....
