how much is too much
Im running g5x2 with pacesetter lt and a tune my question is how big of a shot can i run with these mods on stock injectors and stock pump? coming from a nx kit.
Restricted User
Agree. Over 150 you could be in trouble fuel pump wise. Recommend 100 or 125. Thats wet. Dry would require a smaller shot, since you have the larger of the 2 sized LS1 F bdoy injectors, at 28.8lbs you may be able to get away with a smaller 75 shot, maybe 100 but you'd be maxing the IPW out big time, for a 1/4mi not as dangerous, but definately not a roll racer like that.
Restricted User
Again, 125 should be good. You would want to do the things listed in the Sticky up top in the FAQ's. You dont need injectors to run wet. If you read the FAQ's Sticky up top it will break down the pro's/con's of each setup, and what regarded as safety items etc...hell it will probably answer 90% of your questions.
Mike, relax man. I know your running stock everything on your fuel system and swear by it, but unless your selling him a setup and want to be responsible for it if it happens to pop then your doing the right thing using smilies I'm thinking what your thinking, I think.
