For those using timing tuner
Can anyone shed some light concerning the settings page provided in the instructions?
I want to pull 2* of timing whenever I spray but leave my N/A timing alone. Is it just a matter of having the switches in the following positions: (N20 min. RPM at 3000 RPM)
BASE: 0
WOT: 0
RPM: 5
RTD: 2
Also with regards to the max RPM N20 shut-off, I found the configuration section in the instructions. Once you determine your max RPM what switch are you manipulating? Is it the spark base switch you adjust to the appropriate number shown in the table or the RPM switch?
Table on page 7 and 8 of the below instructions.
http://www.fullthrottletech.com/atta...2&d=1103730053
Thanks for any help.
Brian
BASE: 0
WOT: 0
RPM: 5
RTD: 2
Brian
BASE: 0
WOT: 0
RPM: 5
RTD: 2
BASE: 0
WOT: 0
RPM: 5
RTD: 2
Brian
Brian
Matt
