Need Help Please?????
13 Second Truck Club
I have 2004 corvette and I am installing a MSD window switch. Any advice would be apreciated. The model number of the MSD is PN8969 if that helps.
Do a search-
Copied from one of robert56's posts
https://ls1tech.com/forums/showthrea...ight=tach+wire
It's the PCM under the the batt area, and accessible through the wheel well. It's #10 and a white wire, IIRC. You can see the numbers if ya look close, and only one #10 with a white wire.
