Safe to run 28* timing on 50 shot
Old 05-23-2006, 01:12 PM
Mazzenger's Avatar
Default Safe to run 28* timing on 50 shot
Is safe to run a 50 wet shot on a ls1 with 28* of timing? or is that too much timing.
Old 05-23-2006, 04:20 PM
code4's Avatar
Some info here, different opinions.
https://ls1tech.com/forums/nitrous-oxide/511922-pulling-timing-how-much-power-loss.html
Old 05-24-2006, 09:43 PM
mike c.'s Avatar
i run 25deg on a 150 shot w/93oct fuel.
Old 05-24-2006, 10:20 PM
Restricted User
CAT3's Avatar
If everything is fine, 28* should be fine too.
Old 05-24-2006, 10:25 PM
BadAssFast's Avatar
Every car is unique when it come to timing...generally that sounds close enough.
Old 05-24-2006, 10:26 PM
gator's 99TA's Avatar
30 degrees of timing on a 150 wet shot out of the hole on 93 octane. when it got cold i need to hit it with a splash of 100 unleaded. never more than 50/50. big converters help this out.
Old 05-25-2006, 11:23 PM
Dune-LS1's Avatar
No problem at all.
