quick question on the fuel side of wet kit.
2 kits, 2 stages, 2 bottles what size line for a 200 shot to the ground? -4 is fine correct? Im pretty shure just want to make shure...Thanks Also if I wanted to could I just Y off the fuel rail for the 2 fuel selenoids? Or am I spraying too much for that? Never heard of a 200/200 dual stage kit off the fuel rail. (It will be a total of a 400 shot)Thanks guys.
Restricted User
400 off the rail wont work without having good pumps, front FPR and probably a lot of other stuff not to mention tuning. 100/100 thru a -4, Y off the fuel rails is fine, its actually better than 200 single pull off the rail, as long as the stages are activated split.
I'm not sure if we're reading your install correct. Dual bottles with single line off each or combined with 'Y's? I'm currently switched to dual feed lines.A -4 on the dry side. And -6 on the DP if that helps.
Hawk
Hawk
Yea It will be 2 bottles to each seperate nitrous solenoid and basically was wondering if I could just Y off the fuel rail. I guess I will do a stand alone up front and Y off of that? Or do I need 2 pumps so I can run seperate to each fuel solenoid? Thanks
Originally Posted by CAT3
You can run a SA and Y it with one pump.
We were the ones who introduced the self contained dedicated fuel systems to the aftermarket community. We offer two for the F-body. One mounts in the battery area and is held in by the battery hold down clamp.This one requires relocating the battery.
The other one mounts of the front support by the radiator and requires moveing nothing.
Let me know if I can help.
Thanks
Dave
Thanks
Dave
Thanks
Dave
Thanks
Dave
Originally Posted by MPFD
Will a stock fuel pump handle a dry 75, followed by a 125-150 wet off the rail?
Jim C.
Originally Posted by Robert56
Yes, Dave has the c5/z06 stand alone, and at someone's request, one that fits with the Vararam. Dave will get you hooked up, I'm sure.
Robert
Robert
