First Gear Lockout--Robert?
Old 05-28-2006, 05:01 PM
MetallicaMatt's Avatar
Default First Gear Lockout--Robert?
Hey everybody,
I'm doing the 1st gear lockout the way Robert did his with a micro switch.
My question is, how is this going to wire up? Slightly confused where the two terminals on the microswitch would patch into.
I have an NOS wet kit if it helps. I'm assuming I am tappin into the arming wire? i dunno
help me out
Old 05-28-2006, 08:03 PM
bump bump
Old 05-29-2006, 12:22 AM
Robert56's Avatar
Just tap into your wire running to the pedal WOT micro sw. Remember, wire it opposite (you'll need a 3-prong sw from radio hack), meaning when pedal wot micro sw in 1st gear in mashed to the floor and making contact or closed, the 1st gear lock out micro sw on your trans is open. Then when you shift out of first gear the pedal micro sw acts as normal because both sws are now closed, or making contact. This is for a single stage set up. Wiring using this method in a dual stage set-up is a little differnt. Hope this makes sense.
Here is the pic for anyone reading along.
Robert
Old 05-29-2006, 01:30 AM
losiguy's Avatar
Is it possible to do a first gear lock out with an A4? I dont see how? ( Assuming you leave it in Drive or Overdrive to race)
Old 05-29-2006, 05:32 AM
227Hawk's Avatar
A4s require a controller for 1st gear lock-out.
Hawk
Old 05-29-2006, 07:47 AM
Somebody09's Avatar
Hawk
What controller can do this accurately though? The one I use has to "guess" based on an assumed starting point, max RPM, and an RPM drop.
Old 05-29-2006, 10:26 AM
Robert,
I'll go look for a 3 prong, what prongs should go where?
thanks bud!
Old 05-29-2006, 08:13 PM
Robert56's Avatar
Originally Posted by MetallicaMatt
Robert,
thanks bud!
You'll have to figure that out with an ohm meter. One pair will be closed, and one pair will be open, or open circuit/closed circuit. Just check your wot on pedal and then choose the two prongs/terminals on your lock-out that will be opposite. You'll be good to go. Ohm meter can be used as a continuity checker, and that's what your doing.
Robert
Old 05-29-2006, 09:24 PM
Robert56's Avatar
In the electrical sticky now.
Robert
Old 05-29-2006, 10:52 PM
thanks buddy!
