dynotune wet kit results on lt1
Old 06-20-2006, 09:15 PM
97lt1z28's Avatar
Default dynotune wet kit results on lt1
The car is a made 325 on motor and 426 hp and 468 tq on a 150 wet shot at 900 psi. my bottle heater was not getting any hotter than that. The horse power seems low to me for a 150 shot but it runs well and was tuned for safety. Any suggestions on why the hp was so low?
Old 06-20-2006, 10:04 PM
Camaro Bird 1987's Avatar
two reasons... one.. bottle pressure was low.. and two... their kits are probly rated at the flywheel... so you wont get 150 at the wheels.. it is gunna be less.
get the bottle pressure up and you should make 450hp (dont hold me to that.. lol)
Old 06-20-2006, 10:09 PM
97lt1z28's Avatar
yeah i did not excpect to make 150 to the wheels but 125 would have been nice on a wet shot
Old 06-20-2006, 10:10 PM
jdaniels's Avatar
You are correct, Dynotune rates their jetting by flywheel HP.
Old 06-20-2006, 10:15 PM
97lt1z28's Avatar
again i agree all i am saying is that i sprayed 150 shot (granted it was at a lower psi) and only got about 100 hp to the wheels. I will try bumpin the psi up
Old 06-20-2006, 10:16 PM
Frost's Avatar
Well you don't lose 1/3 of your power through your drivetrain, especially not his M6.
Old 06-21-2006, 09:06 AM
97lt1z28's Avatar
any suggestions on getting my psi up? like a bottle blanket or something
Old 06-22-2006, 04:50 AM
Beer99C5's Avatar
I am running a Two stage 200 shot and getting the 150 at the wheels. I am not up on the LT1, but on the dyno a fresh bottle with the same jetting was good for a 30 HP gain. My Base HP NA was 300.
We went with the 50 Dry @ 3000 and 150 @ 4000 RPM Bottle had a bunch of runs on it at this point
433.9 HP 485 Torque
Same jetting as above 50 Dry @ 3000 and 150 @ 4000 RPM but with a fresh bottle
466.8 HP 530 Torque
I don't think the blanket will get the PSI up, it will help retain heat, have you tried setting the heater pressure switch to go to 1025-1050? Remember increasing the pressure will likely change your AFR to the leaner side.
Give Dean/Dan a call, and ask for jetting for 150 at the wheels, thats what they did for my first kit.
Beer
Old 06-22-2006, 03:21 PM
Board Certified Idiot
Z2K_MrJ's Avatar
You Have a Kit..That Rates Theirs At the Wheels..Only thing you Can Do.. TO Help make it Better Is TO DItch.. Your Heater Find a BEtter one To Get PSI around 1100
Old 06-22-2006, 04:48 PM
LS1TECH Sponsor
DynotuneN2O's Avatar
Beer[/QUOTE]
If you have the dynotune heater you can raise the pressure up but thats not the way to go. Just change the jet if you want more power as Beer mentioned. Yes we rate the kits at the engine. With the variations in drivetrain loss its the only way to go. Give us another ring or email or PM if you need! Not sure how much you are loosing due to the Mustang Dyno numbers versus a Dynojet?
Dean
Old 06-22-2006, 05:40 PM
Frost's Avatar
Dear God that's hard to read...
Old 06-22-2006, 05:56 PM
97lt1z28's Avatar
yeah somebodys been ... yeah i might give you guys a call back for new jets. I am happy with the kit i just figured id get more of a 125 to the wheels with a 150, not a 100-105
Old 06-22-2006, 06:09 PM
LS1TECH Sponsor
Yes the HP is a bit low. When you give us a ring we will try to figure it out.
Thanks,
Dean
www.DynoTuneNitrous.com
Old 06-22-2006, 06:12 PM
brad8266's Avatar
You need to check you bottle heater for the proper voltage at the heater. Check the voltage at the connections very close to the heater itself. Then check voltage at the battery. The 2 voltages should not be very much off from each other. If they are there is a wiring issue.
