75 or 100 shot??
Originally Posted by 98h22
so i should get tr-6 plugs before i spray it?
With the dry shot you are very limited by the stock injectors. If you have higher flowing injectors and a walbro pump you can spray a bigger dry shot like a 150 or 175. With stock injectors dont go higher than 125 on the dry shot.
Originally Posted by BIG_MIKE2005
Yes you will want a colder plug (NGK TR-6) also I would get a fuel pressure safety switch (FPSS), Wide open throttle switch (WOT), & possibly a window switch so it will only spray at set RPM's.
