LT1 WOT placement
LT1 WOT placement
im cant figure out where to place the WOT switch on my LT1. I want it by the throttle body but i can seem to get a good spot. Someone help, Thanks alot.
I used the bottom throttle body and bent the bracket.
something like this
or there is this
http://www.harrisspeedworks.com/shop/product.php?productid=16523&cat=322&page=1
something like this
or there is this
I put the WOT switch on the gas pedal. It doesnt get much easier then that. Just bolt it to the rubber stop for the pedal. If you need pics, Ill be happy to post, but its pretty straight foward.
or if you dont have a window switch already you could order
http://www.dynotunenitrous.com/store...?idproduct=194
And just use the TPS. thats what i did.
