Finally got some baseline numbers - Car is DONE!
Old 06-26-2006, 07:31 PM
FastBlackTA's Avatar
Default Finally got some baseline numbers - Car is DONE!
Worked a few electrical bugs out and finished fabbing up some odds and ends....started some street tuning on the car to get it "driveable." (Note - I have been using HP tuners for my high compression, solid roller 402 and it is an awsome program. The alpha-N option makes tuning large cam engines much easier...).
Took the car to the dyno and almost cracked the 500 rwhp mark running nitrous timing and a little rich N/A. I was pleased the the results, and we just headed back last week and hit the 730 rwhp mark with a 250 shot. No signs of head lifting, GM MLS gaskets with 1/2 inch head studs.....somewhere under 10.0:1 A/F at 13 degrees of timing (starting out safe - it always leans out at the track). Only made 3 pulls and we loaded the car up. I haven't turned on the plate yet, and don't feel we will need to for a while, especially since I am running so conservative on the fogger. I'll be doing all of my datalogging at the track from here on out.
Now I just need to get the car to the track! Fabbing up a chute mount as we speak, but with my work schedule I won't be able to do any racing for a month I will be in 3 different states for the next 3 weekends, so racing is a while off.......at least it gives me time to finish up some odds and ends during the week before I take the car out for the first time.
I'll post some pics soon....
Old 06-26-2006, 07:36 PM
ATVracr's Avatar
Good stuff.
The weather sucks right now anyways, not that it will be any better in a few weeks.
Cant wait to see that badMOFO make a pass
Old 06-26-2006, 07:37 PM
Me too. It's been a really long build, but worth it.
8's or bust!
Old 06-26-2006, 08:13 PM
B18B1LS1's Avatar
what kind of power was the old setup, the 9.71 pass? congrats!
Old 06-26-2006, 09:57 PM
I'm really not too sure as to what it was making. I did the same thing I'm doing this year - getting a baseline at the dyno and then gradually jetting up at the track.
I need to get some pics up of the car from start to finish - minitubs, 10 pt cage, and everything else......just finding the time lately has been tough.
Old 06-27-2006, 04:08 AM
Restricted User
CAT3's Avatar
WTF is Alpha-N option? Everything else sounds very good. Definately want to see pics.
Charlie
Old 06-27-2006, 05:20 AM
DopeFedZ's Avatar
Nice to hear she is making some good numbers. Congrats on all the hardwork.
Old 06-27-2006, 06:40 AM
Alpha-N is actually a term used in a megasquirt manual I was reading - whoops. The option I was referring to in the HPTuners program adds fuel based on throttle position (VE Multiplier vs. TPS vs. MAP). It's a huge help in this engine as the MAP readings are all over the place and jump to 85 kpa by just cracking the throttle slightly.
Old 06-27-2006, 09:21 AM
Nitro Dave's Nitrous Outlet's Avatar
Sounds like you are almost there. Make sure to share those finished pics and runs when you are ready.
Dave
Old 06-27-2006, 10:13 AM
8 second mod
Noyzee's Avatar
congrats man, cant wait to see her run!!!!!!
good luck, any idea on the weight of the car?
Old 06-27-2006, 12:01 PM
I'm thinking it should weigh 3100 or so. There is still more weight reduction to do, but lately I've been much more concerned with finishing this thing.
My brother has some scales for his SCCA car....I'll weigh it soon.
Old 06-27-2006, 12:17 PM
8 second mod
Noyzee's Avatar
wow, 3100, nice and light!! good luck man
