What Tuning Required for Dry 100 Shot?
Do I need to reprogram my 98 SS for a 100 dry shot, change plugs? What? It's totally stock with the exception of an SLP Lid. Thanks
nothing. You should be fine. Just make sure your MAF is working properly, your fuel pump is in good condition, you injectors are clean & get some NGK TR6 plugs gapped @ .038"
With the dry kit it will make the stock fuel system pick up the slack & add accordingly. Small dry kits are the easiest by far to use & install.
Just make sure you get all the proper safety equipment.
Window switch,fuel pressure saftey switch,wide open throttle switch,air/fuel saftey
Here are a few example of saftey equipment.should definetley pick up a window switch and fpss
BTLFEDSS
BTLFEDSS
Originally Posted by silverta16
Where does the fuel safety switch go and how? ON a dry shot? Thanks
BTLFEDSS
