nozzle position ?
Old 07-12-2006, 01:12 PM
BIG_MIKE2005's Avatar
Default nozzle position ?
Ok, I have decided 100% for sure that I'm gonna order a single nozzle kit within the next couple months. I would like to know the absolute best location for a single nozzle dry hit. It will be a 100 shot.
Where is best for distrubution across the MAF for more accurate readings??
Old 07-13-2006, 12:35 AM
Robert56's Avatar
Close in the neck with a 90* nozzle aimed at your wires. I showed you my pics? something similar works great on most boxes. Dual nozzles would/could be a little different. I think cat has a box like yours and a single nozzle on one stage, and his is in the middle of box aiming at maf. General rule is closer is richer, farther is leaner. Better to have closer though, if to rich you can tilt nozzle up or down a tad bit to finalize a/f. hope this helps you get started. Also, descreen for dry hits.
Robert
Old 05-03-2007, 05:11 PM
caliswangin916's Avatar
i have a 90 that i want to use as a single coming up from the airfilter, can i just aim at one of the maf wires, or the two on one side, or the single one on one side, or try to get all three maf wires?
Old 05-03-2007, 07:18 PM
BayAreaSS's Avatar
Whoa! brought back from the dead....
