any c6 Nitrous kits for 06 C6?
I'm looking for info on what kits are out there and what features they have. my engine is stock. The only mods right now are a CAI and a thermo. Future mods will likely include headers, cam, etc. I have no plans for major work on the bottom end.
I'm basically looking for a good, safe kit for a stock c6. guessing around a 100 to 150 shot, wet or dry.
thanks in advance
thanks in advance
Closed ex-Sponsor Account
NX build a complete new maf piece for your car. You will need to do a little cutting on the maf to make it all work but once done I feel it is the cleanest, and sexiest looking kit for the C6. Complete with tps Here is the link to the system.
http://www.nitrousexpress.com/Pages/gm_1pc_massair.htm trigger switch.
From that link you can also get to the instructions and read about the install..
CAll me if have any questions? 888-463-2781
Ricky
Ricky
thanks for the quick reply!
I'm a little new to the nitrous game, so a few q's:
1 Any issue with the torque management on the A6?
2 TPS switch is what? Throttle Position sensor? Does this take the place of the WOT switch and a window switch?
3 Any suggestions on how to hide the bottle from view in a C6 and still have room for the targa top? Ready made housing or cases or something to match enterior...maybe something that looks like a trunk partition or subwoofer box (might have just answered my own question there!)
4 what kind of gains should I expect? Do you have a SAE corrected dyno sheet from a stock A6 running a 100 and 150 shot with this kit?
5 Do I need to pull any timing out or make any other changes to my tune? I have had a tune done already
6 Is there a quick and easy way to go from non-nitrous tune to nitrous tune on the 06 corvette computer?
7 This is a dry kit, right? So I should probably not go any higher than a 100 shot, correct Or is 150 doable with my setup?
Here is a link to a Vette/nitrous thread. You can find pics of the installed C6 MAF kit, and also the Cold Fusion PRO Plate kit.
https://ls1tech.com/forums/nitrous-oxide/512363-z06-nitrous-guys-come-c5-s.html
We at Nitrous Direct carry both. One more kit to consider is the PRO Dry kit. Check out our link in sig, then on main page is another link to our new site with additional kits. In old site we have a vette section to check out.
Now on your questions.
1. Not that I really recall? some one else?
2. yes take's the place of wot sw, which of course you could use if you like. You'll still need a ws.
3. Check out the link for insight, also my personal web for ideas.
4. You jet it for the HP gain you want, so 100hp will be 100hp. The jetting that comes in the kits are real close to actual gains.
5. If you have had timing added then yes, likely timing pull will be needed, wet or dry.
6. Yes, with a tuner program, or using a timing tuner, or in your tune on dry hits.
7. The MAF kit is a wet kit. The plate kit is a wet kit and PRO Dry is dry. 150hp easy on wet, and 100/125 easy on dry. higher for both if you like.
Hope this gets you started on your quest.
Robert
Robert
Thanks for the info guys!
I'm leaning toward the NX Maf Kit at this point and purchasing the window switch separate.
With pulling a couple of degrees of timing, what kind of horse power loss should I expect? I was at 342 stock. Now sitting at 355 with a Calloway CAI and a tune.
Any issues fit issues with the calloway CAI and the MAF kit?
Should I pick up some colder plugs as well?
get rid of the tune. an n/a tune usually adds timing and puts the a/f ratio @ like 12.5 across the board. with nitrous you usually wanna be around 11.0 to 11.3 across the board as far as a/f ratio. but you already said you would pull some timing but i recommend a tune. good luck.
if its an NX kit, daves outlet kit, or cold fusion kit you should get 100whp is your on a 100shot.
unless you modified the maf i dont beleive there will be a problem.
yes use NGK TR6 spark plugs. two steps colder than your stockers and are good 2 about 600hp.
I guess the other question I have at this stage, is with the wet kit and the geometry of the ls2 intake, what is the possibility of the fuel puddling in the intake and then being shot through my hood?
TPAS instruction sheet.
3 Any suggestions on how to hide the bottle from view in a C6 and still have room for the targa top? Ready made housing or cases or something to match enterior...maybe something that looks like a trunk partition or subwoofer box (might have just answered my own question there!)?
4 what kind of gains should I expect? Do you have a SAE corrected dyno sheet from a stock A6 running a 100 and 150 shot with this kit?!
5 Do I need to pull any timing out or make any other changes to my tune? I have had a tune done already?
June 05 Vette Magazine complete write on the prototype system.
instructions for MAF kit .
1pc. MAF page.
Ricky
