Zex wet kit w/ MSD window switch 8969 wiring diagrams?
Old 06-19-2007, 07:32 PM
98TADRIVER's Avatar
Default Zex wet kit w/ MSD window switch 8969 wiring diagrams?
i searched on the boards but only came up with a diagram with the zex with msd ws 8956. http://i73.imagethrust.com/images/1V...-breaking.html thats the link to it. heres the pic of it below
i bought a zex LS1 wet kit, along with the msd WS used pn8969, but no directions came with it.
i dont have a fpss but i plan on getting one in the near future.
that should still work though right? and whats up with the arming switch having a ground on it? is that a lighted on/off switch instead of your typical on/off switch?
Old 06-20-2007, 10:40 AM
Todd157k's Avatar
Still works the same. You won't use the Gray. The ground on the switch is for two things. 1) if it's a lighted switch, it provides the ground for the light and 2) safety when the switch is off, grounds the relay.
Get the FPSS now. Cheap insurance. Unless you like swapping motors.
instructions:
http://www.msdignition.com/pdf/8969_frm25515.pdf
Old 06-20-2007, 10:55 PM
98TADRIVER's Avatar
thanks man! i appreciate it, and should be wiring it up before this weekend, and then fill my bottle on friday and hopefully all goes well!
Old 06-21-2007, 09:06 AM
2002_Z28_Six_Speed's Avatar
Is this for the TPS triggered ZEX kit? Thought the input on the TPS sig was 5 v
Old 06-21-2007, 02:30 PM
SSBound's Avatar
is MSD the best?
Old 06-22-2007, 02:40 AM
98TADRIVER's Avatar
i wired it all up just like the diagram shows. no fires lol. hopefully filling bottle this friday or weekend to see how it all works! ill get some pics/ video soon
Old 06-24-2007, 12:42 PM
t6378tp's Avatar
30 on the relay should go to the battery, the white wire on the zex box goes to the tps
Old 06-24-2007, 09:29 PM
Closed ex-Sponsor Account
NXRICKY's Avatar
The drawing is sound with one catch. YOuhave to program your tps first then break the white wires and install on the relay.
Or you could get the ZEX window switch.
Ricky
Quick Reply: Zex wet kit w/ MSD window switch 8969 wiring diagrams?
