Will a Sneaky pete system work for a LS1
Old 09-23-2007, 11:44 PM
Z28Caves60's Avatar
Default Will a Sneaky pete system work for a LS1
Just wondering if a sneaky pete system will work on a 99 LS1?
Old 09-25-2007, 10:06 AM
quickblade's Avatar
Then you might have to fill it up again after the first run.
LOL
just my thoughts. dont see why you couldnt get it installed...
Old 09-25-2007, 10:31 AM
transamfreak01's Avatar
yeah i had a buddy that ran it on his... after a week or two he hated it b/c you always had to fill it up and it doesnt hit very hard and he went to a regular wet set up.
Old 09-25-2007, 02:12 PM
john563's Avatar
are you just looking for something to hide? I heard of some one useing a 2lb bottle in the glove compartment.Dont know if it will fit
Old 09-26-2007, 01:46 AM
Z28Caves60's Avatar
yeah i just wasnt looking for anything too big and i fiugred it would also be easy to hide on the street
Old 09-26-2007, 07:53 AM
02BlackBullet's Avatar
Get a spare glove box out of a parts car, cut the whole interior part of it away, swap out your glove box for said hacked up one, mount a 2.5 or 5 pound bottle inside the dash where you can open the glove box and have easy access to open/change out the bottle as well as to read the gauge to make sure you're good on pressure. Wire up a 50hp dry hit, run the line through the wheel well, hide the noid under the intake box between the top of the condensor and radiator and then throw the nozzle in the intake.
There's your sneeky pete that you can feel and not have to worry about running out in 1 run with a 25 shot.
P.S.
This has never been done before.
Old 09-27-2007, 12:27 AM
McAllenSuperSport's Avatar
do you think its worth 279 bucks for it 20-30 shot I kinda like it its compact and wont get me in trouble so much
Old 09-27-2007, 01:07 AM
Zeke34's Avatar
Part Number: NOS-02620-20
Old 09-27-2007, 01:08 AM
Cheatin' Chad's Avatar
it'll work just fine if it's installed correctly.
Old 09-29-2007, 09:28 AM
john563's Avatar
P.S.
I thought about doing this,but did not know if the 5lb would fit in the glove box.Main reason is easy access to open bottle.Most people mount on the tunnel in the back for easy bottle opening,but just worried if I get pulled over and a cop see it.I know i could invest in a bottle opener,but its just one more thing that can break or have electrical problems and not work.Looking for simplicity and easy access.
Quick Reply: Will a Sneaky pete system work for a LS1
