Look what I got for X-mas!
Old 12-27-2007, 11:34 AM
Ms Eliz's Avatar
Talking Look what I got for X-mas!
I got this for X-Mas for myself!!!
I want to keep an eye on my N2O, anybody else ever run this set up? Doesn't seen to be to popular.....but, got a great deal on that auction site.
The O2alertis the first data recording system specifically designed to record Air/Fuel Ratios with a warning output! Not only does it record up to 2 Wideband Oxygen sensors but it also records engine RPM , battery voltage, and has a programmable Warning output to protect against "lean-out".
Unit is housed in a durable aluminum extrusion with backlit display and is only 4"x3.25"x1.25".
Standard System comes with 1 wideband sensor, engine RPM (does NOT require additional rpm module as with other systems), Battery Voltage, Warning output, and software.
System has options for 1 additonal built in wideband oxygen sensor, plus (EGT) thermocouple, plus 2 analog channels (RPM, pressure, flow, position, external wideband (see our part # ALT-OWBC), etc..., or A/F voltage output).
The Warning output can be used to activate warning light, enable fuel enrichment, shut down NOS or ignition, retard timing, etc.
Recording can be started by preset RPM value or switch.
Adjustable sample rates up to 100 samples per second.
Custom configurations available. Call for info.
Systems are upgradable.
All recorded data can be played back on unit or downloaded and graphed on a PC. PC NOT REQUIRED!
Download to a PC to view all data graphically. Software is Windows 98/NT/XP compatible. Allows viewing of any or all recorded channels, zoom and pan, overlay runs, smooth data, and printing of graphs.
So what do you think?
Old 12-27-2007, 12:18 PM
TARZAN's Avatar
I've personally never seen one, and haven't dealt with one to know...but it looks like a handy lil setup
-Will
Old 12-27-2007, 12:34 PM
1badA3Z's Avatar
Hmm thats a neat setup,how much it set u back!
Old 12-28-2007, 12:32 PM
Z28Camaro's Avatar
Basically what the VCN 1000 Nitrous kit has.
Old 12-29-2007, 07:50 AM
Ms Eliz's Avatar
I nabbed it up on e-bay for 299! Goes for around 675.00 from various sources. Including the second O2 sensor which I got with mine.
Old 12-29-2007, 08:04 AM
Beer99C5's Avatar
Thats an awesome deal for a dual WB with basic logging capability! Let us know how well it works, I especially like the ability to record logs and playback later without having to lug the laptop around.
Old 12-30-2007, 06:01 AM
Ms Eliz's Avatar
Thanks Beer! I'll keep you all in the loop when I install!
Ms Eliz
Old 12-30-2007, 08:18 AM
donkey mule's Avatar
That was a great deal!
Old 12-30-2007, 01:57 PM
jmill96Z's Avatar
Looks like it was a pretty good deal.
Quick Reply: Look what I got for X-mas!
