n20 ????
Old 01-09-2008, 11:51 PM
J_Z28_T's Avatar
Default n20 ????
hey guys if i run 2 - 10 pound bottles and i only have one heater on one of the bottles and these bottles are of course joined on a T fitting will the heater work for both or do i need to get one more heater for the other bottle?
Old 01-10-2008, 09:11 AM
Z-RATED94's Avatar
Either get another heater, or ditch the one you have and use a nano system.
Old 01-10-2008, 09:22 AM
Nitro Dave's Nitrous Outlet's Avatar
You will have to put a heater on the other bottle as well. Otherwise you will never get the pressure up. Unless you just use on baottle at a time leaving the other bottle closed.
Dave
Old 01-10-2008, 09:30 AM
Mike@HSW's Avatar
If you want to save money by not getting another bottle heater simply close the valve on the other bottle. when the first bottle gets low close it and open the other.
I think that would be the most cost effective way to run a two bottle setup. If you decide to go with the dual heaters check out ours, Its easily one of the best on the market in terms of getting the PSI up quickly and retaining the heat.
http://www.harrisspeedworks.com/shop...cat=269&page=1
Old 01-10-2008, 12:24 PM
J_Z28_T's Avatar
Default heaters
thanks for all the help, i know what to do now!
Old 01-11-2008, 01:55 AM
daniel6718's Avatar
2 heaters are best
Old 01-11-2008, 02:32 AM
J_Z28_T's Avatar
Originally Posted by daniel6718
2 heaters are best
u have 2 on urs right bro
Quick Reply: n20 ????
