Spark plugs for brodix heads? - LS1TECH
Thread Tools Search this Thread
Old 01-20-2008, 12:15 PM   #1
jakesz28's Avatar
Default Spark plugs for brodix heads?
I have a set of brodix heads and I'm having problems trying to find the right spark plug charts. On their sight the plugs that are listed to fit these heads are Autolite 51 or NGK B9ES. Does some one have access to a chart that breaks them down into heat ranges. I want to know what plugs I'm going to have to run in these heads for shots of nitrous running from 150 shot up to a 350 hit.
Thanks for the help
jakesz28 is offline   Reply With Quote
Old 01-20-2008, 12:20 PM   #2
The top sticky post #7.
caMnaro is offline   Reply With Quote
Old 01-20-2008, 12:38 PM   #3
jakesz28's Avatar
I may be wrong but I don't think these heads use the same plugs as a LT1 or LS1
thanks
These are converted Brodix -10 heads anyone
Related Topics
Thread Thread Starter Forum Replies Last Post
300 shot spark plugs BigDB Nitrous Oxide 24 08-23-2008 03:32 PM
Brodix or Dart? silvergta Small Block & Big Block Chevy Specific 20 05-06-2008 04:12 PM
Best spark plug with AFR heads? LS1BlackBird99 LT1-LT4 Modifications 4 05-15-2007 08:45 PM
Setup for N2O My01SSCamaro Small Block & Big Block Chevy Specific 8 01-25-2007 12:24 AM
ANYONE have any suggestions?? 68 Maro (problems headers and angle plug heads) The Guy in MY 99TA Chevrolet Camaro 1967-2002 6 05-21-2004 07:07 PM
Tags
350, brodax, brodix, brodix10, correct, fit, good, head, heads, ls1, ngk, plug, plugs, run, spark, track
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
