What are the best spark plugs fro running nitrous?
Old 03-24-2008, 03:48 AM
Z28Caves60's Avatar
Default What are the best spark plugs fro running nitrous?
I got a NOS 5177 kit dry shot iwas just wondering what are the best spark plugs to run with nitrous? Thanks
Old 03-24-2008, 09:47 AM
ChicagoTransAm's Avatar
NGK TR6 ....should be about 15-20 bucks for 8
Old 03-24-2008, 10:35 AM
Chris@NitroDaves
Guest
Posts: n/a
Also the the gap for the plugs should be 35 out of the box. THey are fine to run as is.
-Chris
Old 03-24-2008, 10:50 AM
2002t/a06's Avatar
just like they said. tr6's!
Old 03-25-2008, 10:18 AM
Z28Caves60's Avatar
Anyone got the part number one the NGK TR6's for a 99' LS1??? Im having trouble finding them
Old 03-25-2008, 12:06 PM
2002t/a06's Avatar
i believe the part number is NGK-4177
Old 03-25-2008, 12:12 PM
johnparker07's Avatar
that part number sounds right, i posted it in another thread i just cant recall which one and im not at home to look at the box, but yes ngk tr6's are perfect
Old 03-26-2008, 11:10 AM
Sigforty's Avatar
that is the correct part number for Tr6 plugs. I normally get them from Orielly down here for 1.59 a plug. If you wanted Tr55 they are stock number 3951 and Tr7 are stock number 3526.
Old 03-26-2008, 01:24 PM
Chris@NitroDaves
Guest
Posts: n/a
You sir are correct. NGK TR6 stock # 4177
-Chris
Old 03-26-2008, 04:18 PM
bad6as's Avatar
what power level would tr6 be to hot?
Old 03-26-2008, 04:29 PM
quickblade's Avatar
huh.....
tr6 can handle alot of juice....
there are a few guys that can spray 200 on the tr6, but they are fully tuned.
Some people say you should go to tr7 for 200 shot, but then you hear some peeps say that is too cold......
If that is what you were asking.
Old 03-26-2008, 07:41 PM
BOLO's Avatar
Use to run NGK TR55's. Now w/NX150 shot I run their TR6's.
Old 03-26-2008, 07:49 PM
waterbug1999's Avatar
-Chris
I have never had a full set that at least one or two were WAY off the mark. So, double check the plugs before you install them..
Old 03-27-2008, 07:50 AM
Sigforty's Avatar
Originally Posted by quickblade
huh.....
You have to remember what base modifications the engine has. An engine like mine runs on Tr6s everyday. Now to add juice to my car I would need a set of TR7s. I would say most people with a hot heads and cam setup with all boltons making say 470+ hp would probably be running on Tr6s everyday and Tr7s for the gas.
Old 03-27-2008, 09:14 AM
Restricted User
98Z28CobraKiller's Avatar
Colder plugs are only required once you start getting into higher DCR numbers in an NA application. If the car runs on pump gas w/o detonation, you could run a stock Delco plug without issue (again NA). Running a colder plug when not required will cost you some hp. I run the #8's but I hit mine with a 400 shot.
Old 03-29-2008, 02:47 AM
MeanWS6's Avatar
TR8's work for my setup
jk
TR6's would be ideal for ya boss
Old 04-12-2008, 12:08 AM
black99ls1z's Avatar
if u were to spray a 100 dry shot on stock delco plugs..... whats results would u see good or bad idea
(mods: slp lid and catback)
Old 04-12-2008, 04:57 AM
caliswangin916's Avatar
your engine will pop.
Old 04-12-2008, 08:21 AM
FormulaZR's Avatar
I don't mean to hijack...but sigforty brought something up. My car puts about 430 to the tires on motor. I will be adding a 125 wet system to the car in a few weeks...should I be looking at TR6 or TR7 plugs? If it matters...the car used to have nitrous on it before I bought it and it is still tuned for nitrous.
Zach
Old 04-12-2008, 09:03 AM
1969mach1's Avatar
i have a 2001 A4 with lid, catback flows and a Hypertech. I'm running a 100 wet with stock Delco plugs and stock timming. It runs great, A/F ratio is good. THATS MINE.
Quick Reply: What are the best spark plugs fro running nitrous?
