Whats The Best Spark Plugs For Nos?? - LS1TECH
Thread Tools Search this Thread
Old 04-13-2008, 07:32 AM   #1
Default Whats The Best Spark Plugs For Nos??
HI ALL, JUST WANT TO KNOW THE BEST PLUGS TO USE FOR NITROUS? ITS A LS1 427 WITH DART HEADS, WILSON NOS KIT RUNNING 300HP. I AM CURRENTLY USING NGK R5671a-9, BUT THEY ARE ONLY LASTING ABOUT 5 PASSES. THE BEST ITS GONE IS 8.87 @ 160 MPH. THANKS.
TUFSS3 is offline   Reply With Quote
Old 04-13-2008, 07:45 PM   #2
1969mach1's Avatar
1969mach1 is offline   Reply With Quote
Old 04-13-2008, 08:46 PM   #3
2002t/a06's Avatar
Is your caps lock button broken???
2002t/a06 is offline   Reply With Quote
Old 04-14-2008, 09:15 AM   #4
streetassasin's Avatar
please for the love of god dont call it nos, it is nitrous unless its the N.O.S. (nitrous oxide systems) brand even then its pronounced N-O-S.
And not to be a dick but you have a mid-high 8 sec car and you dont know what plugs to use?
streetassasin is offline   Reply With Quote
Old 04-14-2008, 10:06 AM   #5
bluehawk2's Avatar
Read through the sticky the master nitrous faq ........What compression is your motor?
Maybe some of the nitrous gurus will chime in for you even though you called it naaws..jk
bluehawk2 is offline   Reply With Quote
Old 04-14-2008, 10:07 AM   #6
ATVracr's Avatar
Ngk R5671a-10
What happens to them after 5 passes?
ATVracr is offline   Reply With Quote
Old 04-15-2008, 12:39 AM   #7
Sorry but over here everyone calls it nos, Ok nitrous. It runs 12:1 compression, Running on c16. It starts to miss and carry on then put new spark plugs in it and its fine.
Old 04-15-2008, 09:47 AM   #8
1969mach1's Avatar
Old 04-17-2008, 03:40 AM   #9
STATIE's Avatar
Quote:
Hi Tim - I have been speaking to Phonsey about this too - give him a call and he will sort you out or have a read of this - http://www.ls1tech.com/forums/showthread.php?t=846230 about half way down the page.
Your car looked awesome on the weekend by the way.
Watch out though - I'm only 20MPH behind you now.
STATIE is offline   Reply With Quote
Old 04-18-2008, 04:17 AM   #10
Thanks Statie, I might have to give him a call.
Old 05-28-2008, 01:25 AM   #11
I would go NGK TR6. Perfect plug for boost, or spray. Nice cold plug to keep from overheating and you can get em for less than 2 bucks a piece. Pretty much pre-gapped.
TexasSignature2002 is offline   Reply With Quote
Old 05-28-2008, 01:35 AM   #12
Websy21's Avatar
Quote:
Yup, I had bought some tr8's and after talking to more people and thinking of it more I returned them for a few sets of tr6's. They work and are cheap, change em once a season and give her ****
Websy21 is offline   Reply With Quote
Old 05-28-2008, 01:51 AM   #13
Super Speed's Avatar
I think for a 300 shot you're going to need something a little colder than a tr6...
Super Speed is offline   Reply With Quote
Old 05-28-2008, 08:27 AM   #14
ATVracr's Avatar
I use NGK 11's for anything over 300 shot.
Doesnt mean I'm right but thats what I use.
Old 05-28-2008, 09:01 AM   #15
koolrayz's Avatar
You idiots that are telling someone thats running a 300 shot to run TR-6's need to shut the **** up. Your bad information will cause someone to damage there engine.
koolrayz is offline   Reply With Quote
Old 05-28-2008, 09:19 AM   #16
quickblade's Avatar
Quote:
LOL... yeah I would not use tr6 for a 300 shot... That will not have good results.
quickblade is offline   Reply With Quote
Old 05-28-2008, 09:20 AM   #17
quickblade's Avatar
here you go.
if you search youwill find this, but I posted in here for ya.
Nitrous (one step colder)
Heat Range: 6
Gap: .035 - .038
Plug: NGK TR6 (stock number 4177); NGK TR6IX (stock number 3689); Motorcraft AWSF-22C (copper); Autolite 103; Denso IT-20 (stock number 5326)
Nitrous (two steps colder)
Heat Range: 7
Gap: Consult
Plug: NGK BR7EF (stock number 3346); NGK TR7IX (stock number 3690); Motorcraft AWSFA-12C (copper); Autolite AR94; Denso IT-22 (stock number 5327)
Nitrous (two and a half steps colder)
Heat Range: 8
Gap: Consult
Plug: NGK R5724-8 (stock number 7317); NGK TR8IX (part number 3691); Denso IT-24 (stock number 5328)
Nitrous (three steps colder)
Heat Range: 9
Gap: Consult
Plug: NGK R5724-9 (stock number 7891); Autolite AR93; Denso IT-27
Nitrous (four steps colder)
Heat Range: 10
Gap: Consult
Plug: NGK R5724-10 (stock number 7993); Autolite AR92
Old 05-28-2008, 09:49 AM   #18
11's ...
ShiznityZ28 is offline   Reply With Quote
Old 05-28-2008, 09:32 PM   #19
sonic snake's Avatar
10's or 11's would be fine. We've used 10's up to around 400 hp of nitrous.We have also used autolite ar3932's but they are harder to read.
sonic snake is offline   Reply With Quote
Old 05-29-2008, 09:25 AM   #20
WizeAss's Avatar
Do a search..... TR6 and 300 shot..... and see what comes up
Good advice above!
WizeAss is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Fs: Wilson 95mm throttle body p/n 471095 BIGBEAUTIFULDOLLP51 Parts Classifieds 0 01-25-2015 05:57 AM
plugs for nos. sbf Nitrous Oxide 5 10-13-2014 02:50 PM
FS XFI, Wilson 90mm t body, elbow, intake w/ fuel rails ttcamaro Parts Classifieds 1 05-14-2014 05:44 PM
l92 carb set up 6.0fox Parts Classifieds 2 01-27-2014 09:55 PM
Tags
11, 300hp, 7993, ar92, boost, high, ls1, ngk, nitrous, number, plugs, r5671a10, spak, sparkplug, stock, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
