When I arm my system the fuel noid opens, Help.
Old 04-20-2008, 05:06 PM
WilsonSSS04's Avatar
Default When I arm my system the fuel noid opens, Help.
I installed a Nitrous Outlet LS2 Plate system and have not run it yet. This is my first Nitrous system so it's all new to me. I am trying to set up my Trick Performance Window Switch and everytime I turn on my arm switch fuel flows into the plate. It shouldn't be doing that, I have it set for the 1st stage to kick in at 3k. And have 1st gear locked out, I think...
Mabey I have my window switch set up wrong???
To lock out 1st gear do I run off of the first or second stage?
When I set-up the Window switch do I want just the first channel to say
"0L0" at start up?
I'm confused, ask away I'll answer anything you need to know about my set-up.
Thanks,
Mike.
