stock LS2 200-250 shot progressive
whats up guys, i currently have a progressive 150 wet shot hooked up to a stock ls2 and netted decent results with a cam, but now i want more power! is it possible to tune this stock motor to handle a 200 or even a 250 shot? thank you for your time
basically.... 200 shot at 3krpm is alot worse than a 200 shot at 5krpm..... so If you can set it to only spray a second kit at 5k-6500 rpm you might get by with more. The tune is what also controls the amount of nitrous.
Running a 8 plug, racegas, and only 18 degrees of timing with nice outside temps you can likely get by with a 250 shot on a stock motor much safer..... but who would go thru all that trouble just to make another 100 hp?
