nitrous tune to n/a tune
Old 07-26-2008, 10:23 PM
Gregorya24's Avatar
Default nitrous tune to n/a tune
does ls1 have a tuning program like this
http://tweecer.com/requirments.htm
where you can change the tunes by a button in the car? my car is tuned with efi live any help would be great
i just dont wanna loose my timing with the bottle off
Old 07-26-2008, 10:35 PM
Mike@HSW's Avatar
http://www.harrisspeedworks.com/shop...cat=308&page=1
pulls timing and is RPM activated. You can also use our interface controller to pull timing depending on how much you are looking to pull.
Old 07-26-2008, 10:45 PM
Gregorya24's Avatar
I will be ordering that shortly thanks! so will i have a box inside the car where i can change the timing or will have to change the timing in the engine? do yall have install pics? Thanks Greg
Old 07-26-2008, 10:51 PM
Mike@HSW's Avatar
you can locate it anywhere you want, seems like most people mount them inside the glove box. Either unit opens up and you can change the timing to whatever you want it to be. Tune your car for NA max power, when you hit 3000 rmp (or whatever you set it too) the unit will activate your system and pull the timimg.
Old 07-26-2008, 10:53 PM
Gregorya24's Avatar
Thanks alot for your help mike!
Old 07-26-2008, 10:54 PM
Mike@HSW's Avatar
no problem, give us a call or pm me if you have anymore questions
Old 07-27-2008, 12:53 AM
myfast70's Avatar
Do you own a copy of EFI Live or did someone tune your car with it? You can do a COS (custom operating system) and connect a wire to your PCM that when activated will pull timing out just when you're using the nitrous.
Old 07-27-2008, 01:25 AM
jetlag's Avatar
Old 07-27-2008, 07:48 AM
Destroyer of Exotics
FlashWS6's Avatar
hey greg whats going on bro glad to see ya over here!
-bryan
Old 07-27-2008, 03:38 PM
Gregorya24's Avatar
-bryan
haha ya ive been over here awhile i found my car on here but i dont post on here much unless i needs something. but it looks like im gonna be going with the harris speed works i just picked up my kit about an hour ago
Old 07-27-2008, 03:44 PM
Lt1junkie's Avatar
i have the same situation i have a nitrous motor on a good na/n20 tune and i just pull the timing through my digital 6plus box up to 9.9 degrees
Old 07-27-2008, 08:45 PM
5.7 ute's Avatar
X2
I just have an extra relay that earths this pin when the nitrous is sprayed to pull timing & trim the fuelling tables to suit.( I am using a wet shot but the closest store to get jets is 1000 miles away.)
