Where are you running your N2O main line???
Old 08-02-2008, 08:39 PM
8sec-z's Avatar
Default Where are you running your N2O main line???
I am slowly finding time for my wet nitrous kit install and I would like some ideas on where to place the main line coming out of the bottle. I haven't decided where to mount the 10 lb bottle yet, either, just somewhere in the rear like the spare tire area or remove the cd changer and place a 5lb (which i haven't bought yet) bottle there or just place it where the t-tops mount...
Keep the line under the car and out in the weather or snake it through interior? Pics??
Thanks ahead of time,
Brad
Old 08-02-2008, 09:03 PM
BriancWS6's Avatar
I have my bottle in the spare tire well. The feed line goes from there under the carpet and through the fire wall.
Old 08-02-2008, 09:07 PM
SuperSlow02's Avatar
Sparetire, through the fender well, under the car, up the front fender and through a hole infront of the PCM. Nothing like 2 1in holes in a 02 SS....
Old 08-03-2008, 08:03 PM
krazy4's Avatar
My bottle is in the spare tire well. I have the line going through the door sill and out of the PCM grommet.
Really easy to do.
Old 08-03-2008, 08:41 PM
hashtagBMW
Speed Density's Avatar
Really easy to do.
Same here.
As long as you have enough feed and a good flexible line you should be able to do it in like 30min.
Old 08-03-2008, 10:01 PM
krazy4's Avatar
About how long it took me to do it.
Old 08-04-2008, 01:34 AM
Ruckus46Gt's Avatar
after you do it once it will take you 10-15 mins, 3 screws, and side panel comes off, torq bit for the seat belt, and 2 10mm bolts to slide the computer out of the way. Start from the front push it through the gromet, grab it pull it through and push it through the panel the speakers in grab it from teh spare area then tuck it and go backwards
Old 08-04-2008, 10:10 PM
8sec-z's Avatar
Thanks! I will be getting this started late tomorrow night.
Old 08-05-2008, 12:21 PM
5_02ls1's Avatar
i went a little crasy on mine..lol..I ditched all the monsoon factory wiring and ran the feed line through the monsoon wire loom.....yeah i have alot of free time.....
Old 08-05-2008, 12:35 PM
Rushin's Avatar
Dead center in the trunk (hardtop for me ) for the bottle mount. The line goes under the car along the body seam.
Old 08-05-2008, 02:43 PM
b4ckid02's Avatar
My bottle is mounted in between the rear seats and the line is snaked through underneath the car.
Old 08-05-2008, 05:52 PM
69_YENKO's Avatar
i've had the bottle in the spare tire area and in between the seats and both times i ran the line under the carpet and through the grommet.
Old 08-06-2008, 09:10 AM
Z-RATED94's Avatar
My bottle is mounted on the tunnel between where the back seats use to be. The feed line goes through the grommet in the floor under the car but above the Kenny Brown sub-frame connectors. The car doesn't see bad weather and is just a summer toy, so I feel pretty safe that it will last a while.
