Who is using HP Tuners with NOS??
Old 08-03-2008, 10:21 PM
Dragman's Avatar
Default Who is using HP Tuners with NOS??
What kind of lean #s are getting in low gear in histogram with ur WB??
Old 08-04-2008, 11:37 AM
Dragman's Avatar
anybody??
Old 08-04-2008, 12:24 PM
Todd157k's Avatar
um... kinda not sure what you're asking. I tuned my coupe with A4 and a 150 dry shot. I didn't have much of any lean spike... I also didn't make it a habit of spraying 1st gear. At the strip, I'd start spraying near the top of 1st.
I did pull a little timing under spray (using Robert56's method of g/cyl) but was pretty much dead on at 11.5 afr.
Old 08-04-2008, 12:47 PM
nahasapeemapetalon's Avatar
Same here, being i dont have a MAF i scanned a few runs to see where my g/cyl #'s were. Then i pulled timing accordingly from 2800 rpm and up.
I use a wideband for a/f ratio.
Old 08-04-2008, 02:06 PM
Dragman's Avatar
I also run SD but was wondering what kind of AFR # u get with NOS thru low gear with NOS on. I know we usually get a spike from when NOS comes on. I know we can get a little leaner thru low gear because of less load on motor. Got any scans of NOS with HP Tuners to look at?
Old 08-04-2008, 03:03 PM
No i do it separately with a handheld wideband. I had a spike once last week up to like 13 or something but after that just dropped to mid to low 11s where it stayd.
How far are your fuel and n20 solenoids from the nozzle or plate? They recommend under 18" to eliminate or lower the spike so to speak.
Old 08-04-2008, 03:31 PM
Todd157k's Avatar
I'll have to look. I don't think I kept any. I sold the car several months ago. I'm sure I still have the tune file though.
Old 08-04-2008, 08:03 PM
Dragman's Avatar
Dont need any files just like to look at other NOS runs that spray from starting line!
Old 08-04-2008, 10:21 PM
Todd157k's Avatar
well, that would leave me out. Never shot off the line. Traction was a problem in 2nd, much less 1st.
Old 08-04-2008, 10:23 PM
Dragman's Avatar
I use M/T 295x17s DR & never have a issue with hooking!
Old 08-06-2008, 02:54 PM
JoeyGC5's Avatar
When I first jetted my TNT F1 kit for 150 it would spike to 15:1 for about 30mSec then right to 11.8 afr. I lengthened one of the nitrous nozzle lines by 12" and never had any other lean spike from it. The Dyno Tune and HSW kits I've put on never really had enought time to look/noticed any lean spikes as they were 100hp or lower shots.
