250 shot using 93 octane???
how much nitrous will 93 octane support????what is the highest shot ( wet or dry ) people are using with 93 octane fuel???this is a fuel question only.. i have used 93 octane fuel with a 150hp shot and an occasional 200hp shot..
I have used a 225 shot on a low compression sbc motor. I have had good luck but most will not reccomend it. I used it on a throw away motor and it lasted for years. Keep with the 150 shot
Most smart guys wouldn't push it to see how far they can go. We take precautions so we dont blow a motor or ringland, or burn a hole in the piston. With a 250 shot I say you need to have a dedicated fuel system with C16 in it. If you go with a 300 you need to start mixing C16 in with your 93. Max on 93 IMO would be a 150 shot.
