What else do I need? 100 shot!
I have a Trailblazer SS RWD with an intake, 160 tstat, and msd wires. Im installing a ZEX Nitrous 100 wet shot tomorrow. I have a WOT and window switch.
What plugs do I need?
How do I tap into fuel?
Am I safe without a tune?
Do I spray before or after the MAF?
THANKS!
THANKS!
The Tech2 won't show you wideband A/F...only narrowband and that won't help.
Definitely invest in a wideband setup, or have it checked on a dyno. MarylandSpeed sells an LC-1 w/ digital gauge setup for $259 shipped.
THANKS!
THANKS!
Hard to beat TR6 plugged gapped at .035"
On the front of the driver side fuel rail is a cap, take that off and you'll see the schrader valve (basically looks like a tire stem valve). Remove the schrader valve and tap into the rail.
You really should get a tune. If not, start out small and check it with a wideband. Then work your way up.
Dry shot goes in before the MAF. A wet shot goes in after the MAF. I highly recommend a TB plate, like what Nitrous Outlet sells.
