Need some help from the single plane intake guys
Old 08-18-2008, 01:36 AM
Gimp98TNT's Avatar
Default Need some help from the single plane intake guys
I cant seem to get my junk running after i swapped to a vic jr. I'm looking for a HP Tuners file from someone running any single plane intake, I'm pretty sure thats whats holding me back. I realize the isn't the pcm forum, but i figure it the best place to get some help.
TIA
Jim
Old 08-18-2008, 11:49 AM
mrr23's Avatar
weird. when i put mine on, it started right up and ran. i did have to add some to the Base Runing Airflow table. if i remember, i'll upload my file, when i get home. you'll have to play around to get it to fit your tables, as mine is a 2000.
can you upload yours for me to view? also, if you have a log file as well.
Old 08-18-2008, 05:04 PM
Gimp98TNT's Avatar
I'll upload tomorrow, car does start and run. Once it warms up it will just die after 5min or so. Doesn't matter if its idling or im giving it gas it will still die. If it dies while im giving it any gas i usually get a backfire along with it.
Old 08-18-2008, 06:19 PM
mrr23's Avatar
weird doesn't sound like a tune issue. anyways here's my tune. i'm running SD mode, as i removed the MAF.
File Type: hpt
