is 25*degrees enough timing to spray 150
when i got tuned my timing was at 29*, thats like as much timing as you can put in before you get some pinging but besides that its at 25* now is that enough degrees to spray a 150 wet shot are do i need to take out more
Most reccomend pulling 6 degrees for a 150 shot...they do it for a reason..It's safe and still runs good. Don't try to run the ragged edge..it's not worth much power and it can make for a bad day.
If you have a wideband and a way to log with 25*, it would certainly be worth a try. On a 150 shot I run 24* and on a 200 shot I run 22*. I aim to have my AFR between 11.0-11.5 on both shots.
Don't forget about spark plugs either. TR6 or 103 is ok for a 150 shot. I run AR94 since I spray 200 most of the time. I always use a plain copper core.
